TwinTurbo.NET: Nissan 300ZX forum - Gear grind is a common issue on the Z with manual
Subject Gear grind is a common issue on the Z with manual
Posted by jzack on July 02, 2019 at 8:49 AM
  This message has been viewed 301 times.
In Reply To 91 300zx Manual .2nd gear kicks back and grinds. posted by amezcuaz32 on July 01, 2019 at 10:00 AM
Message transmission. Mine would get worse, usually in summer driving, once the tranny tunnel got heated up from the exhaust system.
Redline MT-90 is a popular replacement transmission fluid used to address grind. It made my tranny a lot better. If you decide to change the fluid also consider doing the rear diff (while under the car) using the appropriate gear oil for it (not the MT-90). Rear diff is probably due unless you have records showing otherwise...
