TwinTurbo.NET: Nissan 300ZX forum - No that's not normal.
Subject No that's not normal.
Posted by DVDBURN (MD) on June 30, 2019 at 9:38 AM
  This message has been viewed 290 times.
In Reply To Is this coolant temp normal? posted by dancefloor on June 25, 2019 at 05:26 AM
Message When the temp meter reads half way like that when you know your temp is much higher it means one of three things. A bad connection to the temp sensor, a bad temp sensor or a loose nut that holds the circuit board to the temp gauge inside the cluster (requires removing the temp gauge from the cluster to fix).
www.mytwinturbo.com
Nissan Data Voice on YouTube
