TwinTurbo.NET: Nissan 300ZX forum - Re: can a short shifter cause shifting problems?????
Subject Re: can a short shifter cause shifting problems?????
Posted by Metacom on June 24, 2019 at 9:07 PM
  This message has been viewed 324 times.
In Reply To can a short shifter cause shifting problems????? posted by amezcuaz32 on June 24, 2019 at 03:25 PM
Message Yes they can.
Check your trans fluid is correct and not old. Adjust your clutch pedal. Check your shift bushings aren't disintegrated. There are multiple things that can cause gears popping out. Worn synchros, mainshaft thrust clearances, worn speed gear dog teeth....
But yours is mostly likely the unknown short shifter, and lack of maintenance.
