TwinTurbo.NET: Nissan 300ZX forum - Re: wiring trouble! UPDATE
Subject Re: wiring trouble! UPDATE
Posted by Aztecz32j on June 13, 2019 at 10:19 PM
  This message has been viewed 333 times.
In Reply To wiring trouble! posted by Aztecz32j on June 12, 2019 at 10:35 AM
Message I have tested both the EGI and the IGN COIL fuse box relays at the orange wires that reach the ecu. The relay clicks and shows a low voltage on both circuits/ relays. i tested the wires under these relays and there was only one wire not getting power on the ign coil relay it was coming from the front loom which might be a problem. But this wouldnt explain why nothing in the car works, now the dash lights wont turn on the only thing that works is the ecu light and it throws a 55 code any help?
