TwinTurbo.NET: Nissan 300ZX forum - Dude thanks! (n/m)
Dude thanks! (n/m)
DrVolkl
on May 29, 2019 at 11:55 AM
Here's a link that may be helpful
posted by spicyZ
on May 29, 2019 at 11:54 AM
Issues with starting...
DrVolkl
12:02:11 05/24/19
Manual or auto?
spicyZ
13:30:41 05/24/19
Re: Manual or auto?
DrVolkl
16:39:51 05/24/19
Clock and climate go black when turning the key normally
Summeronthechain (MN)
12:14:03 05/30/19
Hard to believe it’s the relay again. Two things
jzack
13:36:54 05/24/19
Re: Hard to believe it’s the relay again. Two things
DrVolkl
16:41:28 05/24/19
I think it was just coincidental. Relays are pretty
jzack
21:57:25 05/24/19
BTW - generally the key ignition switch isn’t something
jzack
12:11:15 05/25/19
DrVolkl
18:50:41 05/28/19
To eliminate some systems (but not your ignition switch) >>
ZUL8TR
08:11:50 05/26/19
Well there’s a green plastic disc in two pieces on my floor
DrVolkl
12:31:26 05/28/19
Yes - that's it. Crawl under the dash and have a look
spicyZ
07:35:18 05/29/19
Ordered two new discs (might as well do the brake as well)
DrVolkl
11:41:57 05/29/19
spicyZ
11:54:40 05/29/19
Dude thanks! (n/m) -
DrVolkl
11:55:32 05/29/19
FWIW - if you decide to do the bypass safety switch
jzack
13:49:02 05/30/19
Well now that I know how easy it is to simply press it
DrVolkl
15:26:15 05/30/19
*thumbs up* (n/m)
spicyZ
07:13:54 05/31/19
The hard disks do not press in easily with limited room >>
ZUL8TR
11:05:32 06/04/19
Re: Well there’s a green plastic disc in two pieces on my floor
speedy_Z
09:35:32 05/29/19
something simple to check would be your battery connections.
brandonz
07:09:41 05/28/19
2nd- it was years ago but seems the symptoms are similar
Agent X
07:57:18 05/28/19
Re: Issues with starting...
Adam393
12:06:13 05/29/19
