TwinTurbo.NET: Nissan 300ZX forum - transmission speedo gear/ mph kph cluster(PLEASE HELP)
Subject transmission speedo gear/ mph kph cluster(PLEASE HELP)
Posted by Hyperactive on May 26, 2019 at 11:05 AM
  This message has been viewed 334 times.
Message I have a automatic na 2+2 that I did a tt engine/auto trans swap with a rhd clip. I have tried to get answers and no one seems to have done the write on up this specifically anywhere. everyone says to just use the na speedo gear in the tt auto trans but the na and tt solenoids or different diameters. so the only way I can use the na gear is on the tt solenoid but even though it fits and seats properly to the trans the mounting screw location is 180 degrees from where it is suppose to be and cannot be rotated so I secured it in place temporally to see if speedo on cluster would work but no luck. so I put the tt gear back on the tt solenoid and the only way I can get a cluster to read is if I use the kph cluster. im sure that speed has to be off but more importantly will the make my odometer incorrect as well. any help/answers to any of these problems is greatly appreciated.
