TwinTurbo.NET: Nissan 300ZX forum - 50psi cranking seems high.
Subject 50psi cranking seems high.
Posted by MLPS300ZX on May 20, 2019 at 10:55 PM
  This message has been viewed 367 times.
In Reply To I did a fuel pressure test today. posted by BannonZ on May 13, 2019 at 02:57 PM
Message It should be about 43psi during cranking and drop down to 37 after it has vaccum at idle. Although that difference does not seem like it would be causing this issue.
At idle when you remove the vaccum line from the FPR it should bring the pressure back up to 43psi.
Random things to double check:
Throttle position sensor (hard idle switch)
Fuel Temp Sensor
Steps to double check the hard idle switch on the TPS.
https://conceptzperformance.com/wiki/index.php/Throttle_Position_Sensor
