TwinTurbo.NET: Nissan 300ZX forum - That's it. It's on TTs only. I have a fuel pressure gauge...
Subject That's it. It's on TTs only. I have a fuel pressure gauge...
Posted by MLPS300ZX on May 13, 2019 at 2:45 PM
  This message has been viewed 316 times.
In Reply To Re: Re: Starting issue: Continued posted by MLPS300ZX on May 12, 2019 at 09:34 PM
Message and could see fuel pressure was still zero when I turned the key and primed the pump.
Once I let it crank I could see the fuel pressure slowly rise, then free fall back to zero once I stopped cranking.
If I cranked it over long enough it would build enough pressure and start, stumble and then hold correct fuel pressure.
I replaced this valve and it solved the problem.
This does not sound like your issue though because a bad fuel pressure check valve would not be temperature dependent.
