TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Probably transmission problem.
Subject Re: Re: Re: Probably transmission problem.
Posted by Metacom on April 26, 2019 at 5:28 PM
  This message has been viewed 277 times.
In Reply To Re: Re: Probably transmission problem. posted by mapsz32 on April 26, 2019 at 02:47 PM
Message Could back probe the harness side terminals on the AT control unit regarding the TPS circuit and check the voltage sweep to make sure that signal is correct all the way up to the AT control unit?
If that signal is good then test the AT control unit itself.
