TwinTurbo.NET: Nissan 300ZX forum - power steering pump twin turbo
Subject power steering pump twin turbo
Posted by valleyz32 on April 17, 2019 at 12:29 AM
  This message has been viewed 339 times.
Message Hello everyone, I removed the hicas system on my z32 tt. seeing the rear hicas is no longer used and is blocked off at the back, can you just block the extra pipe coming from the p/s reservoir, pull the spring and plunger out of the hicas part of the pump and weld up the banjo fitting and just put the bolt back in the p/s pump? I am considering this way since i want to reduce as many hoses as possible but wanted to run by here before i do anything and see what yall think. Thanks!
