TwinTurbo.NET: Nissan 300ZX forum - Are your motor mounts, trans and diff mounts all original?
Subject Are your motor mounts, trans and diff mounts all original?
Posted by Polish on April 13, 2019 at 1:59 PM
  This message has been viewed 263 times.
In Reply To Lurching problem while cruising or letting off throttle? posted by Zashi on April 13, 2019 at 12:10 AM
Message In either case, how many miles on those components? Might be some kind of drivetrain slop from a bad mount somewhere. That can cause strange clunks when going off/on throttle from the whole motor/trans/diff moving around when it should be tightly mounted. BDE OE-Style engine mounts and OEM trans mount would probably be the first things I would try. You'll also want to check your Driveshaft's Center Support Bearing.
