TwinTurbo.NET: Nissan 300ZX forum - Re: Do you know if they had short blocks at one point?
Subject Re: Do you know if they had short blocks at one point?
Posted by ZBOOSTT on April 11, 2019 at 4:09 PM
  This message has been viewed 239 times.
In Reply To Do you know if they had short blocks at one point? posted by nissubaru on April 10, 2019 at 02:58 PM
Message Are you able to do a compression test? For best results pull all spark plugs and wedge the throttle flaps wide open to allow air in with little restriction. Be sure you unplug the CAS. If the compression is fine, then you shouldn't have to worry about the block/pistons. Test out what you have first so you don't spend money unless your sure you need to.
