TwinTurbo.NET: Nissan 300ZX forum - Help! I screwed up - Timing Belt Service
Subject Help! I screwed up - Timing Belt Service
Posted by Bigwill837 on March 30, 2019 at 10:19 AM
  This message has been viewed 555 times.
Message Prior to aligning the crank/cams at TDC (Timing Belt Service Wiki), I cut the timing belt off. To my knowledge, the crank and cams have not moved independently from each other since cutting off the timing belt. However, nothing seems correctly aligned. This is the current state of the crank gear, intake cams, and exhaust cams:
Crank Pulley:
PS Exhaust Cam Gear:
PS Intake Cam Gear:
DS Intake Cam Gear:
DS Exhaust Cam Gear:
What should I do? Can I just put the belt back on without moving the crank or cam gears?
