TwinTurbo.NET: Nissan 300ZX forum - Sounds like you exhausted the Fuel Issue
Subject Sounds like you exhausted the Fuel Issue
Posted by Cjw3 on March 23, 2019 at 12:17 PM
  This message has been viewed 245 times.
In Reply To Yes posted by BannonZ on March 23, 2019 at 12:00 PM
Message Then it Sounds like a Week Spark.. as Fuel is hard to Lite when the Cylinder is cold.. I need to see if there is some way to check the health of the spark.. Have you pulled the Coil Pack and put a plug in it and cranked it cold to see if you get a good Spark?/..
You have replaced the ECU.. so the ECU Spark Drivers for the PTU have been changed.. sounds like to only remaining piece is the Wires and Ground points..
Can you do a Voltage check on the +12 to Ground Wires at a Coil Pack.. that will be the Black wire in the Center.. and the Black outside wire.. ( Except on Cyl 1 ).. you need above 10 Volts during cranking else the Spark will be thinn..
Cj
