TwinTurbo.NET: Nissan 300ZX forum - Re: Reset is the same.. Not done the MAF Disconect
Subject Re: Reset is the same.. Not done the MAF Disconect
Posted by zromtech on February 24, 2019 at 6:00 PM
  This message has been viewed 315 times.
In Reply To Reset is the same.. Not done the MAF Disconect posted by Cjw3 on February 24, 2019 at 04:19 PM
Message Is the IACV good? Not losing spark in a cylinder?
One cause for off idle stumble on warm-up is when the ECU runs in 'rapid catalyst heating mode'. This is only activated when coolant temperature at engine start is between 10C and 35C, the ECU retards timing to dump heat out the exhaust to get the catalytic converters up to their spark point sooner. This mode is disengaged above 55C and when RPM > 2600, something else to consider during your troubleshooting.
- Sam
