TwinTurbo.NET: Nissan 300ZX forum - Reset is the same.. Not done the MAF Disconect
Subject Reset is the same.. Not done the MAF Disconect
Posted by Cjw3 on February 24, 2019 at 4:19 PM
  This message has been viewed 303 times.
In Reply To Re: Cold Weather Tuner/User Question posted by zromtech on February 24, 2019 at 02:04 PM
Message This is also the Same Zed that had a 'Too rich on Throttle Blip' just off Idle.. It would stumble badly if you let it get below 1K RPM when starting out from a lite.
Early on in the Troubleshooting, the TPS/MAF/Injectors have been swapped between good Cars..
I've had to flatten out the ' Enrichment Graph' to where it's now flat like some TT Tunes.. And that fixed the Off idle Stumble..
Fuel Pressure is 'Normal'.. No injector leakage suspected.. and it will Idle in Closed loop watching the O2 Sensors Readings ( narrow Bands )..
Fuel Trims are running around 100.. with one bank ~106 and one bank ~98..
This car is put together from 3 zed parts.. it's plated as a '90 built in Late '89, running a 8 But Auto ECU chipped with a Manual E-Rom in a Moates Conversion..The Car is a Manual, and the Chasis was Org a Manual with all the Proper Wiring..
Thanks Sam..
