TwinTurbo.NET: Nissan 300ZX forum - Re: Drained and filled tank with new gas. I tried this...
Metacom
on February 20, 2019 at 2:08 PM
posted by AnimalZTT (TX)
on February 20, 2019 at 12:20 PM
yah only running with starter fluid pretty good sign its a fuel problem, though far as I understand if your injectors weren't receiving power they wouln't of been clicking when you turned the CAS unless the CAS was bad.
Help Diagnosing No Fuel
AnimalZTT (TX)
11:15:42 02/17/19
Fooled around a little more and I believe I hear injector...
AnimalZTT (TX)
12:07:00 02/17/19
Re: Fooled around a little more and I believe I hear injector...
Metacom
20:18:25 02/17/19
Pulled an easy to get to one and right at 13 ohms (n/m)
AnimalZTT (TX)
20:29:54 02/17/19
So fuel is getting through the damper and pressure is...
AnimalZTT (TX)
09:43:16 02/19/19
Re: So fuel is getting through the damper and pressure is...
Metacom
12:40:29 02/19/19
AnimalZTT (TX)
12:20:45 02/20/19
Re: Drained and filled tank with new gas. I tried this... -
Metacom
14:08:35 02/20/19
AnimalZTT (TX)
15:25:30 02/20/19
Figured out the solution...
AnimalZTT (TX)
11:30:02 02/26/19
