TwinTurbo.NET: Nissan 300ZX forum - Re: So fuel is getting through the damper and pressure is...
Subject Re: So fuel is getting through the damper and pressure is...
Posted by Metacom on February 19, 2019 at 12:40 PM
  This message has been viewed 284 times.
In Reply To So fuel is getting through the damper and pressure is... posted by AnimalZTT (TX) on February 19, 2019 at 09:43 AM
Message All 6 injectors 11-13ohms?
is that 4 year old gas you're still using? Any signs of rodents/mouse poop? Seen a couple cars sit for a bit and rodents chewed on harnesses causing weird problems
So at first you were thinking no fuel to injectors but had good pressure and can hear the pump prime and how you're smelling fuel/exhaust? Try clear flood start, hold accelerator pedal all the way down and attempt to start?
