TwinTurbo.NET: Nissan 300ZX forum - Check the rear HICAS inner tie rod ends
Subject Check the rear HICAS inner tie rod ends
Posted by Doug71zt(CAN) on February 09, 2019 at 10:23 PM
  This message has been viewed 281 times.
In Reply To Help with Suspension/Steering posted by FrozTTy on February 01, 2019 at 10:40 AM
Message With the car at normal ride height. Can be a bit difficult to do but sometimes the inners will feel tight when the car is on the hoist and the suspension is unloaded. Then you put it on the ground and the inners are loose.
I usually just disconnect the outer tie rod ends and check the inners for wear. It doesn't take much play for the rear end to feel very unstable. They are also pretty cheap on Rockauto or such.
