TwinTurbo.NET: Nissan 300ZX forum - I recommend test fitting dry to check for interference
Subject I recommend test fitting dry to check for interference
Posted by LitlElvis on January 28, 2019 at 10:57 AM
  This message has been viewed 352 times.
In Reply To BDE Half Moon Plug Install Q... Sealant? posted by Adam393 on January 19, 2019 at 12:13 PM
Message The machined section on the heads has sharp edges and if damaged, a burr will prevent the half-moons from installing fully. If you can get the half-moons to dry-fit properly, you will not have any problem installing with RTV.
If your head has a burr, you can use some 100 grit wet-dry sand paper with grease on it to catch the sanding debris to knock down the burr.
When installing permanently, use a small amount of RTV (use the same gray RTV as the exhaust valve cover will use). If the half-moon is above the VC gasket surface, tap on a block of wood with a hammer to seat it. Never rely upon the valve cover to push it into position.
