TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: timing is fine but i might have found something?
jgelly
on January 18, 2019 at 4:04 PM
posted by Metacom
on January 14, 2019 at 02:18 PM
fuel pressure is good, brake booster good, however, it does have a stage 3 clutch in it(previous owner idk why) could this cause a problem, or need an adjustment, and if so where can i find instructions
1990 n/a 5speed
Need help
jgelly
13:11:48 01/10/19
This is an air issue, you have a leak some place. (n/m)
13:50:14 01/10/19
You say no vacuum leaks. How did you test? (n/m)
Barry (NJ)
14:15:44 01/10/19
Re: Need help
jgelly
18:18:43 01/10/19
Re: Need help
Metacom
21:58:20 01/10/19
Re: Re: Need help
jgelly
09:04:46 01/11/19
If you're concerned that it's the ECU, you can swap
CarolinaZ_TT
12:38:14 01/11/19
Re: If you're concerned that it's the ECU, you can swap
jgelly
12:44:16 01/11/19
Re: Re: If you're concerned that it's the ECU, you can swap
Metacom
13:47:04 01/11/19
Re: Re: Re: If you're concerned that it's the ECU, you can swap
jgelly
23:15:52 01/11/19
jgelly
14:13:35 01/12/19
jgelly
14:20:31 01/12/19
Metacom
22:09:02 01/13/19
jgelly
09:19:23 01/14/19
Metacom
14:11:15 01/14/19
jgelly
09:20:28 01/14/19
Metacom
14:18:59 01/14/19
Re: Re: Re: Re: timing is fine but i might have found something? -
jgelly
16:04:36 01/18/19
Re: Re: Re: Re: Re: timing is fine but i might have found something?
Metacom
17:59:37 01/18/19
Re: Re: Re: Re: Re: Re: timing is fine but i might have found something?
jgelly
15:49:46 01/19/19
Re: Re: Re: Re: Re: Re: Re: timing is fine but i might have found something?
Metacom
21:06:26 01/20/19
Re: Re: Re: Re: Re: Re: Re: Re: timing is fine but i might have found something?
jgelly
14:41:16 01/21/19
Re: Re: Re: Re: Re: Re: Re: Re: Re: timing is fine but i might have found something?
Metacom
15:11:57 01/21/19
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: timing is fine but i might have found something?
jgelly
22:31:59 01/21/19
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: timing is fine but i might have found something?
Metacom
00:12:53 01/22/19
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: timing is fine but i might have found something?
jgelly
13:45:38 01/24/19
Timing is fine but i might have found something?
Metacom
15:44:17 01/24/19
Re: Timing is fine but i might have found something?
jgelly
16:16:54 01/24/19
Re: Re: Timing is fine but i might have found something?
Metacom
21:23:23 01/24/19
jgelly
15:49:11 02/03/19
