TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: timing is fine but i might have found something?
Subject Re: Re: Re: timing is fine but i might have found something?
Posted by Metacom on January 14, 2019 at 2:11 PM
  This message has been viewed 419 times.
In Reply To Re: Re: timing is fine but i might have found something? posted by jgelly on January 14, 2019 at 09:19 AM
Message While pressing on the brake with the booster hooked up and you're hearing a hissing sound? most likely a bad booster:
Hook it back up, with your foot on the brake you should feel the pedal drop slightly when the engine starts. If it doesn't that's more proof the booster is bad or the check valve.
Let the engine run a minute or two, turn it off. Slowly Press the brake pedal several times. You should feel pedal sink low the first time and then get hard to press and higher. If it doesn't, another sign of a bad booster/check valve.
