TwinTurbo.NET: Nissan 300ZX forum - Re: I still thinks it’s the fuel regulator or damper...
ChezZ
on January 10, 2019 at 10:32 PM
posted by itsa300zx
on January 10, 2019 at 09:10 PM
but there was no dripping going on in the vac lines from those two things tho... Do I pinch the vac lines? what are the effects that I should expect to see?
Leaking fuel from pcv hose
ChezZ
18:17:25 01/10/19
Badly leaking injector or injector o-ring would be
jzack
18:26:14 01/10/19
Re: Badly leaking injector or injector o-ring would be
ChezZ
19:59:56 01/10/19
Actually that’s a good suggestion about a bad r
jzack
22:23:19 01/10/19
Re: Actually that’s a good suggestion about a bad r
ChezZ
22:35:36 01/10/19
I'm going to point out the obvious
CarolinaZ_TT
07:52:06 01/11/19
Re: I'm going to point out the obvious
ChezZ
00:02:56 01/12/19
Re: Leaking fuel from pcv hose
njz
20:22:59 01/10/19
itsa300zx
21:10:01 01/10/19
Re: I still thinks it’s the fuel regulator or damper... -
ChezZ
22:32:54 01/10/19
I was thinking apply vacuum with a manual pump
itsa300zx
22:51:35 01/10/19
Re: I was thinking apply vacuum with a manual pump
ChezZ
22:56:22 01/10/19
Yes, that’s what I would try. Just be ready to shut
itsa300zx
23:05:12 01/10/19
Re: Yes, that’s what I would try. Just be ready to shut
ChezZ
23:16:09 01/10/19
Probably best to do both of them...also I think the
jzack
23:25:14 01/10/19
