TwinTurbo.NET: Nissan 300ZX forum - Re: Badly leaking injector or injector o-ring would be
ChezZ
on January 10, 2019 at 7:59 PM
posted by jzack
on January 10, 2019 at 06:26 PM
how do I know if there is gasoline all over my vacuum system? I'm thinking of uv dye but will it still be safe to drive under the circumstance(engine hydrolock)? Could it just be a stuck-open pcv valve?
Leaking fuel from pcv hose
ChezZ
18:17:25 01/10/19
jzack
18:26:14 01/10/19
Re: Badly leaking injector or injector o-ring would be -
ChezZ
19:59:56 01/10/19
Actually that’s a good suggestion about a bad r
jzack
22:23:19 01/10/19
Re: Actually that’s a good suggestion about a bad r
ChezZ
22:35:36 01/10/19
I'm going to point out the obvious
CarolinaZ_TT
07:52:06 01/11/19
Re: I'm going to point out the obvious
ChezZ
00:02:56 01/12/19
Re: Leaking fuel from pcv hose
njz
20:22:59 01/10/19
I still thinks it’s the fuel regulator or damper...
itsa300zx
21:10:01 01/10/19
Re: I still thinks it’s the fuel regulator or damper...
ChezZ
22:32:54 01/10/19
I was thinking apply vacuum with a manual pump
itsa300zx
22:51:35 01/10/19
Re: I was thinking apply vacuum with a manual pump
ChezZ
22:56:22 01/10/19
Yes, that’s what I would try. Just be ready to shut
itsa300zx
23:05:12 01/10/19
Re: Yes, that’s what I would try. Just be ready to shut
ChezZ
23:16:09 01/10/19
Probably best to do both of them...also I think the
jzack
23:25:14 01/10/19
