TwinTurbo.NET: Nissan 300ZX forum - Cylinder Head Decking Info
Subject Cylinder Head Decking Info
Posted by Adam393 on December 20, 2018 at 9:38 PM
  This message has been viewed 291 times.
Message Does anyone have thickness specs on what the TT heads should be in order to run the stock HG? I cannot find the info on how much material can be removed from the mating surface and still stay within spec for the OEM HG.
Also which surface to which surface should be measured with a caliper to measure this? I'm not sure if EM-29 in the Service Manual is what I'm after or not
