TwinTurbo.NET: Nissan 300ZX forum - Re: Help diagnosing A/F ratio differential between passenger
Subject Re: Help diagnosing A/F ratio differential between passenger
Posted by MagicMike on December 18, 2018 at 6:54 PM
  This message has been viewed 353 times.
In Reply To Help diagnosing A/F ratio differential between passenger posted by SirpriZ on December 18, 2018 at 06:10 PM
Message I have certain conditions where my banks are significantly different. Not so much a full load, more light loads.
lots of things can cause variance in afr readings. wideband placement especially.
Also airflow. Throttle bodies balanced? do they remain balanced through 0 to 100% throttle?
What ecu? Add some fuel to the lean side and see what happens.
