TwinTurbo.NET: Nissan 300ZX forum - A stuck open injector doesn’t mean the ECU is bad.
jzack
on December 10, 2018 at 2:18 PM
Re: Could use a test light LED to monitor the injector signal
posted by ZTom
on December 10, 2018 at 01:46 PM
Injectors mechanically can stick open. If signal testing reveals the ECU is signaling correctly likely injector will need to be pulled and replaced. I’d try some injector cleaner first in fuel tank — might be able to unstick it?
1992 300zx TT
ZTom
21:50:06 12/09/18
jzack
09:35:38 12/10/18
ZTom
13:46:05 12/10/18
A stuck open injector doesn’t mean the ECU is bad. -
jzack
14:18:29 12/10/18
^Yeah
-Grimm-
15:51:52 12/10/18
Re: ^Yeah
ZTom
22:35:44 12/12/18
Yep. The electromagnetic coil has no effect on the
jzack
23:25:54 12/12/18
Re: Yep. The electromagnetic coil has no effect on the
ZTom
22:43:09 12/14/18
ZTom
13:48:49 12/10/18
Here you go
-Grimm-
13:52:39 12/13/18
