TwinTurbo.NET: Nissan 300ZX forum - Could use a test light LED to monitor the injector signal
Subject Could use a test light LED to monitor the injector signal
Posted by jzack on December 10, 2018 at 9:35 AM
  This message has been viewed 377 times.
In Reply To 1992 300zx TT posted by ZTom on December 09, 2018 at 09:50 PM
Message from the ECU and see if it blinks while car is idling. That would be a good way to verify if the ECU was signaling the injector to fire. Just be sure a low current LED tester is used.
If LED remains on all the time, probably a bad ECU. If it blinks, injector is probably stuck open.
BTW - Why do you believe the issue is with #4 cylinder?
