TwinTurbo.NET: Nissan 300ZX forum - Knock sensor is very high resistance. 584 ohms is too
Subject Knock sensor is very high resistance. 584 ohms is too
Posted by jzack on December 06, 2018 at 8:49 PM
  This message has been viewed 350 times.
In Reply To need some advise with code 34, please posted by wh0sjeff on December 06, 2018 at 08:20 PM
Message low. Think more like 500k ohms. The knock sensor is basically a crystal element that when vibrated generates a small voltage. The right vibration (ping) creates a signal the ECU recognizes so it can take action.
This link explains how to test:
[ http://www.zhome.com/ZCMnL/PICS/detonationSensor/detonationSensor.html ]
The sensor is grounded through its mounting bolt — so only 1 wire on harness plug (sensor side) gets tested — ground your meters other resistance test lead to body ground (or negative terminal of battery).
FYI - the reason the resistor trick works, the knock connector harness on ECU side of things is a two wire connector with 1 wire being ground.
