TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Just a long shot to check — verify the AT cooler isn’t
Subject Re: Re: Re: Just a long shot to check — verify the AT cooler isn’t
Posted by infoschumi on December 05, 2018 at 3:43 PM
  This message has been viewed 311 times.
In Reply To Re: Re: Just a long shot to check — verify the AT cooler isn’t posted by infoschumi on November 23, 2018 at 05:31 PM
Message So I checked the temperature with an infrared laser gun and temperature trough radiator is fine,nothing clogged.For example engine coolant outlet is 176F and inlet is 158F,so radiator is cooling I guess.The only suspicious thing I saw was that the right throttle body cooling line was much hotter than the left throttle body cooling line,and the heater core hoses were way hotter(194F) than the engine outlet to radiator(176F).Automatic gearbox radiator which is part of the radiator was a little cooler than the radiator.
