TwinTurbo.NET: Nissan 300ZX forum - Front side of rad has the AC condenser so might be >.
Subject Front side of rad has the AC condenser so might be >.
Posted by ZUL8TR on November 14, 2018 at 3:02 AM
  This message has been viewed 366 times.
In Reply To Re: A simple check that has worked for me even if rad was>> posted by infoschumi on November 13, 2018 at 11:34 AM
Message difficult to get reliable readings on the rad with the IR gun. But you can check the thermostat and other areas on the engine where coolant flows. Check inlet and out temps from the engine to the rad.
Cooling system flow diagram, note top alum hose tube on engine is To rad and bottom alum hose tube is From rad
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=lc&slide=8 ]
ZUL8TR
