TwinTurbo.NET: Nissan 300ZX forum - Or if you are daring, with engine warm, use a folded piece
mrchips
on November 12, 2018 at 10:17 PM
Get the car to operating temp (turn it off) and spin by hand
posted by -Grimm-
on November 12, 2018 at 05:07 PM
of cardboard to hold fan blades while a 2nd person starts the car. If you keep the fan from spinning it's shot.
IR guns are dirt cheap at Hobo Freight and work well.
Overheating
infoschumi
18:50:32 11/10/18
What method was used to get the actual temperature
jzack
17:59:53 11/11/18
Re: What method was used to get the actual temperature
infoschumi
11:24:08 11/12/18
Actually what I was getting at - how are you certain of
jzack
18:24:04 11/12/18
Sounds like it's time for an update .....
zx299
19:32:12 11/11/18
This link might be worth looking over too?
jzack
09:01:23 11/12/18
Re: This link might be worth looking over too?
infoschumi
11:28:26 11/12/18
My stock gauge has performed like your's for years (even
SirpriZ
13:24:04 11/12/18
I had a similar overheating issue, ended up being the clutch
SkiFly01
15:41:04 11/12/18
-Grimm-
17:07:20 11/12/18
Or if you are daring, with engine warm, use a folded piece -
mrchips
22:17:50 11/12/18
Re: Or if you are daring, with engine warm, use a folded piece
infoschumi
11:30:26 11/13/18
Well that sounds wrong
-Grimm-
12:36:20 11/13/18
Re: Well that sounds wrong
infoschumi
05:44:39 11/14/18
infoschumi
05:49:03 11/14/18
A simple check that has worked for me even if rad was>>
ZUL8TR
05:14:38 11/13/18
Re: A simple check that has worked for me even if rad was>>
infoschumi
11:34:49 11/13/18
Front side of rad has the AC condenser so might be >.
ZUL8TR
03:02:11 11/14/18
Just a long shot to check — verify the AT cooler isn’t
jzack
23:06:44 11/14/18
Re: Just a long shot to check — verify the AT cooler isn’t
MightyAA
13:31:19 11/21/18
Re: Re: Just a long shot to check — verify the AT cooler isn’t
infoschumi
17:31:25 11/23/18
Re: Re: Re: Just a long shot to check — verify the AT cooler isn’t
infoschumi
15:43:51 12/05/18
