TwinTurbo.NET: Nissan 300ZX forum - the stock turbos are good for up to 20lbs, 22lbs on e85
Subject the stock turbos are good for up to 20lbs, 22lbs on e85
Posted by Boostjuice on September 24, 2018 at 10:10 AM
  This message has been viewed 393 times.
In Reply To Re: Do I even need to upgrade injectors and ECU? posted by Bigmatthew86 on September 23, 2018 at 07:04 PM
Message At this point though they loose their efficiency, what is going to limit you on boost is injector size. does your car currently have a remapped ecu? if it does not, I would not run 14 psi without the remapped ecu for the 370cc injectors. if you already have the 740cc injectors ready to install and have prepaid for the ecu from specialty z why would you not put them in. then you would have absolutely no problem, at that point the injectors will flow way more, and you could max the turbos out if you really wanted to.
