TwinTurbo.NET: Nissan 300ZX forum - Re: Eprom backwards?
Subject Re: Eprom backwards?
Posted by rhombicblue on September 16, 2018 at 4:13 PM
  This message has been viewed 395 times.
In Reply To Eprom backwards? posted by mds484 on September 16, 2018 at 03:04 PM
Message The direction in which the socket is installed is irrelevant. Ideally, it should be installed with it's notch facing the Red LED. Just don't forget to insert the chip with it's notch facing toward the Red LED. You indicated that your engine "was running really rough and not holding an idle" with the chip not installed. I don't believe your engine should be running at all with the chip not installed.
