TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Question for people using nistune.
Subject Re: Re: Re: Question for people using nistune.
Posted by MagicMike on September 12, 2018 at 10:21 PM
  This message has been viewed 291 times.
In Reply To Re: Re: Question for people using nistune. posted by Nismo300zx1990 on September 12, 2018 at 08:19 PM
Message Perhaps you misunderstood what I was suggesting...
You should always use matched injectors, however, when injectors are tested there is typically a small difference between them.
My suggestion was to get your injectors flow tested (like you should do for any set of injectors before installing) and put the 2 that flow the most in numbers 5 and 6.
If you are using stock injectors and stock ECU, forget the lot.
