TwinTurbo.NET: Nissan 300ZX forum - Sounds like...
Subject Sounds like...
Posted by GrecV2 on September 05, 2018 at 6:47 AM
  This message has been viewed 372 times.
In Reply To TT won't idle at same time as brake, and stop/tail warning posted by Vert93 (MN) on September 03, 2018 at 05:18 PM
Message ... all your dash lights are coming on because the car died. Think turning your key to "on" just before turning it all the way to crank. All the warning lights come on.
And if it worked fine for a couple days/cold starts after the work and then started acting weird, it sounds like your ECU did it's "learning" thing and ended up self adjusting to where you're at now.
I might reset the ECU and see if it goes back to idling correctly
Also, why is setting the adjustment screw a "band aid" fix? If you disconnect the valve's connector, set the screw to 700 RPMs or thereabout, reconnect the connector and idle stays around 750... you've just set idle...
Former Stage V addict... off the wagon.
