TwinTurbo.NET: Nissan 300ZX forum - Re: It will just barely run @ about 550 rpm. And within seconds,
Subject Re: It will just barely run @ about 550 rpm. And within seconds,
Posted by TheKryptKeeper on September 04, 2018 at 9:53 PM
  This message has been viewed 352 times.
In Reply To It will just barely run @ about 550 rpm. And within seconds, posted by Vert93 (MN) on September 04, 2018 at 05:54 PM
Message Well, it sounds odd enough that you should probably just eliminate the obvious. Follow the quick check in this link for testing the IACV and ACC.
http://www.twinturbo.net/nissan/300zx/forums/technical/view/1161018/Yes.html
When that is done, ohn out the coil packs and confirm good grounds. Now ohm the injectors.
All good? Throw your vacuum testing hockey puck in the intake and fill the engine with 5psi. Any vacuum leaks?
Last, check the main harness connectors by the engine fuse box. Squirrelly shit can happen there if water gets in.
Answer these and we will all have a better direction to point you in.
