TwinTurbo.NET: Nissan 300ZX forum - It will just barely run @ about 550 rpm. And within seconds,
Subject It will just barely run @ about 550 rpm. And within seconds,
Posted by Vert93 (MN) on September 04, 2018 at 5:54 PM
  This message has been viewed 404 times.
In Reply To Can you explain more on what happens when it "wont idle"? posted by Polish on September 04, 2018 at 12:21 PM
Message it dies. Or sometimes less than a second. It will start right back up, then die unless you give it a little touch of the throttle. Other than the idle issue, it seems to run great.
The brakes don't seem to have anything to do with the idle. It doesn't matter if you are pressing on the brake pedal or not. The only thing that is brake related are the 2 warning lights on the dash. The "brake" light is on, and the "stop/tail" warning light are both illuminated on the gauge cluster (the one that tells you that you have a tail light burned out/not working). I don't know if those 2 lights are related to the idling problem or if that is a separate issue. But they did both happen at the same time.
