TwinTurbo.NET: Nissan 300ZX forum - There are 2 grounds hooked up on the back of the plenum.
Subject There are 2 grounds hooked up on the back of the plenum.
Posted by Vert93 (MN) on September 03, 2018 at 8:57 PM
  This message has been viewed 402 times.
In Reply To Is the 'Gang Point' Ground hookedup at the back of the Penum (n/m) posted by Cjw3 on September 03, 2018 at 07:04 PM
Message Both are held on with a small 10mm bolt. The one on the passenger side has one thicker wire. And the one on the drivers side has 4 thin wires. Are those what you are referring to? If so, unfortunately they are hooked up.
If you are talking about a 3rd ground, please let me know where so I can check. Thanks for the response!
