TwinTurbo.NET: Nissan 300ZX forum - It doesn’t matter. However, often times the corrosion
Subject It doesn’t matter. However, often times the corrosion
Posted by jzack on August 28, 2018 at 10:11 PM
  This message has been viewed 302 times.
In Reply To Code 13 posted by rightzedfred on August 28, 2018 at 04:52 PM
Message travels up the wiring harness. So something else to check. How far up the harness did you splice in the new coolant connector? Also maybe check your splice - could just be bad?
Totally possible the new sensor actually failed - the FSM has a procedure for testing it. Could just try substituting the old sensor as a trial.
Might also be worth burping your coolant system. It’s possible an air pocket is a causing bad sensor readings although I think this is a long shot.
