TwinTurbo.NET: Nissan 300ZX forum - Before. With the nuts off I could barely raise the hoses
Subject Before. With the nuts off I could barely raise the hoses
Posted by 240Z FeO2 on August 10, 2018 at 5:55 PM
  This message has been viewed 328 times.
In Reply To Excellent info. Did you unbolt the hoses before or after posted by ZXoltan on August 09, 2018 at 04:54 PM
Message on the studs. And the hose blocks are very thick. Because the work area is so tight, I don't think you want to drop the compressor and try to loosen them later. But I could be wrong. Lacking advice to the contrary, my approach was, "pick the devil you know rather than the devil you don't."
I used a gear wrench on the the one farthest from the block and, with a bit tighter clearances on the other, a box end is probably supreme.
Haven't done the reinstall. I waited to see if I could get the compressor out before I ordered a replacement.
Chance favors the informed
