TwinTurbo.NET: Nissan 300ZX forum - Was it running OK before the plenum pull? >>>>>>>>>
Subject Was it running OK before the plenum pull? >>>>>>>>>
Posted by ZUL8TR on August 01, 2018 at 2:38 AM
  This message has been viewed 346 times.
In Reply To having issues with my z posted by manie on July 31, 2018 at 04:03 PM
Message If so then something(s) didn't go back correctly.
"----it dosent wanna run without the maf sensor pluged in--"
Do you mean it will not run with the maf plugged in? If so it will not.
You need the correct 5 prong maf for the car.
Did you do a fuel rail/injector pressure check for leaks?
Did you correctly attach all vacuum hoses?
What injectors did you get for replacement?
Are they new or rebuilt?
Are they the upgraded pintleless 1993+ type for the NA or did you use the same original pintle type?
The 1993+ pintleless OEM are the better ones for stock replacement but require an adapter to fit into the lower intake manifold. I used these when I replaced all 6 on my 1992 NA.
Be cautious buying parts before you do a detailed diagnostic, these cars have been known to suck you wallet dry.
ZUL8TR
