TwinTurbo.NET: Nissan 300ZX forum - Yes, tough to do if its a DD
Doug71zt(CAN)
on July 25, 2018 at 8:09 AM
Well, any work I perform is always thought-out
posted by FrozTTy
on July 25, 2018 at 07:11 AM
Lots of wire available at a u-pick (pick-n-pull) junkyard.
Pick the newest truck there and cut the long harness runs out. Most places won't charge you very much at all.
Best to ask before you go crazy with the cutters.
Another Intermittent Hesitation Post....
FrozTTy
08:14:43 07/22/18
Did you clear that code yet? (n/m)
compirate
09:57:39 07/22/18
No I have never pulled the motor (n/m)
FrozTTy
10:43:26 07/22/18
I meant from the ECU. (n/m)
compirate
15:03:35 07/22/18
i dont have any datascan etc
FrozTTy
19:11:30 07/22/18
Check the coolant temp sensor plug/wiring first
Doug71zt(CAN)
17:46:21 07/22/18
Solid insight...thanks I will look around (n/m)
FrozTTy
19:10:01 07/22/18
My PTU is direct wired - no more subharness
FrozTTy
09:04:29 07/23/18
Z32 wiring corrosion is nothing compared to
Doug71zt(CAN)
02:10:20 07/25/18
FrozTTy
07:11:30 07/25/18
Yes, tough to do if its a DD -
Doug71zt(CAN)
08:09:25 07/25/18
I was also curious about the coil packs.
FrozTTy
09:06:00 07/23/18
This. Even check up the harness at length from connectors.
MixManMash
14:28:11 07/23/18
Would electrical contact cleaner help with this type of
FrozTTy
07:19:03 07/24/18
Electrical contact cleaner is not going to get under the
MixManMash
07:32:01 07/24/18
Well duh. I meant for actual cleaning.
FrozTTy
10:52:41 07/24/18
Is there a certain 'kind' of wire that must be used? (n/m)
FrozTTy
13:54:24 07/24/18
Not really. I used CSA type TEW which is UL type MTW. (n/m)
MixManMash
07:43:37 07/25/18
