TwinTurbo.NET: Nissan 300ZX forum - Well duh. I meant for actual cleaning.
FrozTTy
on July 24, 2018 at 10:52 AM
Electrical contact cleaner is not going to get under the
posted by MixManMash
on July 24, 2018 at 07:32 AM
If I can expose all the corrosion, is it "ok" to simply clean it off and be good to go?
Or will it show face again quickly because it's already made its way down the wiring.....?
Thanks
Another Intermittent Hesitation Post....
FrozTTy
08:14:43 07/22/18
Did you clear that code yet? (n/m)
compirate
09:57:39 07/22/18
No I have never pulled the motor (n/m)
FrozTTy
10:43:26 07/22/18
I meant from the ECU. (n/m)
compirate
15:03:35 07/22/18
i dont have any datascan etc
FrozTTy
19:11:30 07/22/18
Check the coolant temp sensor plug/wiring first
Doug71zt(CAN)
17:46:21 07/22/18
Solid insight...thanks I will look around (n/m)
FrozTTy
19:10:01 07/22/18
My PTU is direct wired - no more subharness
FrozTTy
09:04:29 07/23/18
Z32 wiring corrosion is nothing compared to
Doug71zt(CAN)
02:10:20 07/25/18
Well, any work I perform is always thought-out
FrozTTy
07:11:30 07/25/18
Yes, tough to do if its a DD
Doug71zt(CAN)
08:09:25 07/25/18
I was also curious about the coil packs.
FrozTTy
09:06:00 07/23/18
This. Even check up the harness at length from connectors.
MixManMash
14:28:11 07/23/18
Would electrical contact cleaner help with this type of
FrozTTy
07:19:03 07/24/18
MixManMash
07:32:01 07/24/18
Well duh. I meant for actual cleaning. -
FrozTTy
10:52:41 07/24/18
Is there a certain 'kind' of wire that must be used? (n/m)
FrozTTy
13:54:24 07/24/18
Not really. I used CSA type TEW which is UL type MTW. (n/m)
MixManMash
07:43:37 07/25/18
