TwinTurbo.NET: Nissan 300ZX forum - I was also curious about the coil packs.
FrozTTy
on July 23, 2018 at 9:06 AM
Check the coolant temp sensor plug/wiring first
posted by Doug71zt(CAN)
on July 22, 2018 at 05:46 PM
How to test them? Was there ever a FINAL answer as to which coil pack version is "better"?
My Z has ~175k miles, but put in a "JDM motor/tranny" about 40k miles ago.
Another Intermittent Hesitation Post....
FrozTTy
08:14:43 07/22/18
Did you clear that code yet? (n/m)
compirate
09:57:39 07/22/18
No I have never pulled the motor (n/m)
FrozTTy
10:43:26 07/22/18
I meant from the ECU. (n/m)
compirate
15:03:35 07/22/18
i dont have any datascan etc
FrozTTy
19:11:30 07/22/18
Doug71zt(CAN)
17:46:21 07/22/18
Solid insight...thanks I will look around (n/m)
FrozTTy
19:10:01 07/22/18
My PTU is direct wired - no more subharness
FrozTTy
09:04:29 07/23/18
Z32 wiring corrosion is nothing compared to
Doug71zt(CAN)
02:10:20 07/25/18
Well, any work I perform is always thought-out
FrozTTy
07:11:30 07/25/18
Yes, tough to do if its a DD
Doug71zt(CAN)
08:09:25 07/25/18
I was also curious about the coil packs. -
FrozTTy
09:06:00 07/23/18
This. Even check up the harness at length from connectors.
MixManMash
14:28:11 07/23/18
Would electrical contact cleaner help with this type of
FrozTTy
07:19:03 07/24/18
Electrical contact cleaner is not going to get under the
MixManMash
07:32:01 07/24/18
Well duh. I meant for actual cleaning.
FrozTTy
10:52:41 07/24/18
Is there a certain 'kind' of wire that must be used? (n/m)
FrozTTy
13:54:24 07/24/18
Not really. I used CSA type TEW which is UL type MTW. (n/m)
MixManMash
07:43:37 07/25/18
