TwinTurbo.NET: Nissan 300ZX forum - jump the pins on the larger connector to the relay.
Subject jump the pins on the larger connector to the relay.
Posted by rightzedfred on July 22, 2018 at 10:40 PM
  This message has been viewed 360 times.
In Reply To Single click sound under driver fender well,car won't start posted by aquariuscsm on July 21, 2018 at 10:32 PM
Message and then try to start it - that will bypass your relay (and clutch switch, and anti theft I think). I just had the pleasure of diagnosing this same thing. Thought it might be the relay, but it was clicking, and I tested for voltage at the starter solenoid when the key was turned to the "start" position and it showed voltage, so I assumed it was the starter. Low and behold, new starter didn't work either. I also discovered the previous owner bypassed the anti-theft and the clutch safety switch. Regardless, today I jumped the larger connector to the relay and it started - so I will be getting a new relay
