TwinTurbo.NET: Nissan 300ZX forum - Double check the connections on the solenoid as there are 3
Subject Double check the connections on the solenoid as there are 3
Posted by MixManMash on June 20, 2018 at 5:58 PM
  This message has been viewed 282 times.
In Reply To Greddy Profec (n/m) posted by Schmeal (NV) on June 19, 2018 at 09:35 PM
Message ports.
Make sure you are using the instructions for actuator type.
Port 2 should go to the wastegate. Port 1 should go to your boost pressure source. Port 3 should be left open or you can install a threaded filter.
