TwinTurbo.NET: Nissan 300ZX forum - Wastegate stuck closed?
Subject Wastegate stuck closed?
Posted by Schmeal (NV) on June 19, 2018 at 10:17 AM
  This message has been viewed 376 times.
Message Installing an EBC and while initially setting up I was getting higher than expected levels of boost. I bypassed the solenoid and connected the wastegate hoses back to the OEM location and I'm getting 11 psi. Boost jets were removed during the install.
Anyone have this issue? I only read one other post where the guy had a loose actuator bracket. I guess I'm going to crawl under there this weekend and see if I can move the actuators manually and maybe apply some pressure from my air compressor directly to the lines.
Work on your own car, and don't half ass it.
