TwinTurbo.NET: Nissan 300ZX forum - Could use a wire from the ignition solenoid without a relay
Subject Could use a wire from the ignition solenoid without a relay
Posted by -Grimm- on June 15, 2018 at 10:27 AM
  This message has been viewed 348 times.
In Reply To Looking for Electrical help - wiring relay posted by Zbullet on June 14, 2018 at 08:21 PM
Message As long are youre using a fused distribution block and not drawing tons of power you should be fine.
Also, there isnt any issue sending the 12V signal through the coil to ground. It functions as any other circuit would, internal resistance of the coil will keep it from acting as a short. Standard SPDT auto relays have enough internal resistance to only draw ~25 mA on the signal side
1992 300ZX NA 5 Sp KH6 (Dead)
1990 300ZX NA Auto 2+2 732 (Dead)
1991 300ZX TT 5 Sp TH1 (Stock)
1990 300ZX TT 5 Sp KH6 (Stock Turbos) (Est. 400 HP)
1990 300ZX TT 5 Sp 326 (GT600R) (Est. 600 HP)
2004 G35 Sport 6MT (DD)
2014 Nissan Murano (DD)
1969 Chevy C10 383/TH350 (Toy)
1969 Chevelle LS1/T56 (Toy)
