TwinTurbo.NET: Nissan 300ZX forum - Thanks for the help. I had the valve cover gaskets replaced
Subject Thanks for the help. I had the valve cover gaskets replaced
Posted by 300NASeattle on June 11, 2018 at 8:19 PM
  This message has been viewed 294 times.
In Reply To Forgot to add — not unusual to have the EGR tubes that posted by jzack on June 11, 2018 at 06:09 PM
Message ago (15,000 miles). I told him to replace all the hoses under the plenum when he did the job but he must have thought the water hoses were good because they were not replaced according to the work sheet. Just the 2 PCV valves (that look different from the OEM I bought), breather hoses, and 1 intake plenum gasket o-ring.
And he didn't feel the need to replace the rubber grommets around the valve cover screws.
I need to look the the part numbers to verify he did the exhaust gaskets. I see (1) valve cover gasket set (JVS-00572), 1 intake plenum gasket (A4033-30P02) and 1 intake plenum gasket (14033-30P05). The last two serials look like Nissan so I hope the first is the exhaust gaskets.
$900 labor for $205 work out parts. I am glad I decided to do it myself this time.
